A friend recently dropped off a Hafler DH-500 that he recently acquired in unknown working condition. It appears to be in very good original shape, modulo missing one of the speaker fuses. But because he knows it hasn't been powered up in some time, he asked if I'd do a slow-start on it to avoid letting out any magic smoke.
So, I plugged it into my variac-dim-bulb-volt-and-current-metered rig, and slowly brought it up. It began to spring to life at about 80V mains input ... I began to hear a faint hum, and then the dim-bulb filament started to glow gently. I heard a relay click -- not sure which one -- and the bulb filament started to glow a bit more ... checked the meter and the amp was drawing 1.5A. At this point, the variac was dialed up to 120V but the meter was reading only about 95V at the input to the amp.
So, at this point I shut it all down. No acrid smells, but the fan did not spin (I don't recall if it's temperature controlled on this model or not) and decided to post here for advice.
I suspect the bulb is providing too much resistance for the amp to start up properly. It's a 250W photo flood. It never came on brightly as would happen if there was a problem... just a slight glow of the filament.
I suppose I should take the bulb out of the chain and try with just the variac, and the volt-current meter, but I wanted to get some advice here first.
Thx.
Thx.
