simulacra75
Anytime i've been replacing any component on Marantx SR1000L i've always fired it back up on the DBT to be sure there wasn't a problem. Everytime i did this, it "worked" as expected, initially bright then dimming down, so "as expected".
Last weekend i replaced 2 transistors and 2 caps on the volume/balance board PE00. When i started it on the DBT since, it burns bright and stays bright. If i then power down the receiver and then power on again, it starts bright, then dims down again, so "working" again. Anyone seen this type of behaviour before or do i have some kind of short in there? Thank you.
