Eventual solution: Bad solder job on one replacement transistor!
Problem: Weak (barely audible) left channel.
The service manual is available online and is of good quality.
Next steps:
- Constant regardless of input source
- Also weak channel through headphones
- Rebuild of Control Amp and Main Amp circuit boards
- De-oxit of all pots and switches
- Verified replacement component orientation is correct
- Jumpers removed, L/R signal from external source fed directly into Main Amp, both channels present
- Transistor values of Control Amp measured (Q501-Q506, originally 2SC458 and replaced with KSC1815 as advised), all voltages both (a) ballpark to specs and (b) identical between L/R channels
- Power Supply output voltages all measured, all OK close to spec
Next steps:
- Verify continuity through SW1a / SW1b pots (already verified this once, will do it again)
- Jump channel wiring around to try to isolate where the signal gets lost (?)
- Do whatever you guys tell me to do!
