Guys,
I'm wondering if anyone is using a Stanton 881 cart with the Jolida J9 preamp.
I'm using this setup into my new Rega Elex R.
I'm running the Jolida with the dip switch settings for 47K and 220 PF, per Stanton recommendation. Stanton actually reco's 275 PF, but the Jolida's closest match is 220.
I have replaced the cheap op amps with the much better Burr Browns, and I'm using two 1960s Sylvania Gold Brand 5751s.
While it sounds VERY, very good, what I'm noticing is that treble seems to be too extended. When I lower the stylus onto the record, I'm hearing every bit of the groove noise, DEFINETLY more than if I plugged the Turntable into the Rega Elex R directly.
I changed load to 1000 instead of 47K, No good! Killed ALL the highs. So, back to 47K
I've added some capacitance, that seemed to help a little. I might go more on that.
Any thoughts?
Thanks,
Mick
