motleypixel
I said stumble, not "fallen and I can't get up". Also, OG for the subject: Old Goat/Old Gear. Here's the deal, it's two-fold really. 1. I have loads of time. 2. Even though #1 sounds good, I'm on a fixed income so budget takes priority.
First, it seems search is not working on the site, correct? Is there an ETA on restoration? I seem to recall there's a format in google to search sites, just forgot so sorry if this is something that's been answered before.
So, let me start with my needs, think of it as a use case: Need to drive two 8ohm passive bookshelf speakers and an active subwoofer with only coax input. Need an integrated amplifier that has "at min" two channel (at least 30W/ch), sub coax out, tone controls for passive speakers, nice-to-have (sub volume/freq), and at least one RCA input (if separate DAC is used, which is likely). I need the ability to stream HD audio to/from (receive/transmit) via quality codec such as APTX-HD or LDAC. I need the ability to input SPDIF optical/toslink from my CD player. I need the ability to listen to either my CD player, TT (Pioneer PL-7) or Streaming music with my bookshelf speakers/sub or my BT headphones that support APTX-HD (Bower & Wilkins PX7). Seems easy right? Well, not too many all-in-one options out there unless I'm completely looking in the wrong direction.
My system before: BIC Venturi DV62Si bookshelf speakers, early 90's Sony Integrated Receiver/Amp, early 90's Sony CD player (analog out only), and Pioneer PL-7. This system has served me well over the years. I've thrown many different speakers at it in the past.
My system now, first stab at new cheap audio gear and it's almost what I need. However currently this comes at an unfortunate condition where this new class D amp creates popping through the speakers when I turn on/off main power to the system. It's odd becauses even with the front power switch off on the amp and I turn on power or turn off power the pop occurs. I've even using a filtered/conditioned powerstrip.
Class D Amp: Fosi Audio BT30D with BT antena removed so as not to broadcast BT too far as I'm using a separate DAC for BT. No way to disable BT. https://www.amazon.com/Bluetooth-Au...07K7NJ4QN/ref=cm_cr_arp_d_product_top?ie=UTF8
Fiio BTA30Pro DAC. I really like this DAC for the money: https://www.amazon.com/gp/product/B09J48ZPD4/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
U-Turn Audio Pluto 2 Phono Pre-Amp: https://www.amazon.com/dp/B08C6XZMLR?ref=ppx_yo2ov_dt_b_product_details&th=1
Analog to Digital converter (I'll explain below): https://www.amazon.com/dp/B01HGHNCMW?psc=1&ref=ppx_yo2ov_dt_b_product_details
I'm using all Amazon Basics cables RCA etc. as I feel they are decent for what they are.
So with this setup I can accomplish 100% of my use-case needs. I'll explain the way this is all setup which will explain the Analog to Digital converter need:
Coming out of my CD newer Sony player I have SPDIF optical going to optical in of the DAC. Coming out of my Pioneer PL-7 TT grounded RCA going into the Pluto Phono Pre-Amp, then RCA out going into the RCA in of the analog to digital converter, coming out of that via digital coax it comes into the digital coax in of the DAC. The RCA out of the DAC goes into the RCA in of the Class D amp.
With this setup a can switch via the DAC font controls to play the CD player, TT or Streaming BT to the DAC from my phone to my speakers OR if I choose I can flip the BT switch to transmit to my BT headphones OR I just just flip the switch to DAC to output via RCA to my amp to play over my speakers.
The problem I'm having really comes down to the amp causing this popping. To keep things simple moving forward I'd like to replace that amp with a similar small-sized low cost option to hopefully just remove the popping from occurring. OR, somehow, find another option all-together to fit my use case.
In the end, if I could wish for one thing in the say $300 max budget range I'd want an integrated amp that has digital optical, coax and RCA in, at least 2 channel (30W), digital coax sub out (can be 3.5mm pre-out if there's a cable to convert to coax?), and BT receive AND transmit (HD audio codecs). Maybe there's an option out there? Heck maybe there's an all-in-one option out there? I sure as heck haven't found one yet.
Whew, well, the journey to perfection is awesome because it will never end
Thanks for any and all help in advance.
