2DualsNotEnough said:Nice find,kfa888.I found some full range 12" Utah Celestas a few months ago.Same deal as you-found them in the thrift,went over to housewares,got a butter knife,etc.The cabs I put mine in are a little bigger than yours,but I bet I could go a lot bigger.Mine dont have cones in the center,they have this strange metal doo-hickey instead.My surrounds are cloth also,but these have more bass than what you describe.Im sure youll end up liking yours as much as I do mine.
kfa888 said:I'll feed her tomorrow. :thmbsp:
wineslob said:She is real cutie just like mine! :thmbsp: At 8, mine lives on happy meals!!
Charivari said:At any rate, are you sure that the magical sound you're hearing is due to the point source sound or more to the crossoverless design?- JP
pmsummer said:That's one really cute kid.
Man, are you ever gonna be in trouble in a few years when the boys start coming around.
The two are kind of inextricably entwinged. You lose the point source and simultaneously create the need for a xover when you go to separate woogers and twizzlers. The spatial separation of the two causes lobing and worse mischief, and if you plunk the crossover point anywhere near the midrange there's going to be trouble. And we haven't even begun to explore the topic of time-alignment, of getting the W and T in sync... not that this helps much.Charivari said:..are you sure that the magical sound you're hearing is due to the point source sound or more to the crossoverless design?
Ah, but what about Tannoys and similar DC designs? Those, at least according to the advertising, are supposed to be a fairly close facsimile of a point source speaker while using two drivers. 'Course the crossover at 1.2 kHz is still there to muck some things up, which may explain why I like the midrange on Magnepans better with their single driver operating up a fair bit higher. Now about the time alignment issue, my Infinity Quantum 2s are supposedly phase and time aligned, according to the advertising again. I can say that they sound better than I'd expect for 4-ways.wualta said:The two are kind of inextricably entwinged. You lose the point source and simultaneously create the need for a xover when you go to separate woogers and twizzlers. The spatial separation of the two causes lobing and worse mischief, and if you plunk the crossover point anywhere near the midrange there's going to be trouble. And we haven't even begun to explore the topic of time-alignment, of getting the W and T in sync... not that this helps much.
Now that sounds like a fun experiment, I look forward to reading about the results of it. And wrt the e-stat headphones, I'm working on that bit.wualta said:I'm scheduled to do some futzing with an active Linkwitz-Riley xover here pretty soon and will report on its effect on a '70s dinosaur with a typically bad xover, the ESS amt-II. Meanwhile, see about getting some Ohm Walshes and maybe one of the KEF Uni-Q speakers. And some electrostatic headphones.
As long as the drivers are physically or electrically aligned so they behave as a single driver through the crossover region and the woofer cone is shaped so as not to cause cavity resonances, then yes, the coax driver is a good compromise, which is why I mentioned the KEF Uni-Q. Coax mounting seems such a good idea that I wonder why there aren't more of them. As it is, they seem to serve as exceptions that prove the rule.Charivari said:Ah, but what about Tannoys and similar DC designs? Those, at least according to the advertising, are supposed to be a fairly close facsimile of a point source speaker while using two drivers.
Anytime you complicate things you increase the chance that something will futz up, of course. Theoretically, a proper coax driver should vastly simplify xover design. Real world, the designer would still have to deal with the nonideal characteristics that accompany any passive crossover. Now-- to get hold of a good electronic xover with built-in variable delay... that might drop a train on a few problems..charivari said:'Course the crossover at 1.2 kHz is still there to muck some things up...
As you can see, this would be difficult, since the voice coil of the EMIT/M is mounted far forward of the voice coil for the woofer. But since there are separate drivers, I'd question the need for strict alignment anyway.charivari said:Now my Infinity Quantum 2s are supposedly phase and time aligned, according to the advertising again.
