Synthetic and conventional motor oils are both petroleum based. So are a whole range of chemicals and plastics. The difference is how they are produced. Conventional oils are produced in a traditional “refinery” where crude oil is cracked into its component parts and then additives are blended in to give it the desired properties. The properties of the finished product are very dependent on the “base stock,” the actual crude oil used. The properties of crude oil vary tremendously from the preferred “light sweet crude” to tar like substances.
Synthetic motor oils are built up of components that have been processed to the point they are essentially just “chemicals”. All of the traditional characteristics of the base stock have been processed out. The blenders just chose the component parts that have the characteristics they are looking for and blend them together with the appropriate additive package.
This does have advantages. Synthetic oils have properties that are not found in traditional oils. But just because it can be a superior product does not automatically mean you will benefit from these improvements and it can cause problems.
If the vehicle system is not designed to use synthetic oil and you use the vehicle within it’s ordinary design parameters, there is little benefit but there is risk. Oil seals are designed with specific oils in mind. Using other oils or especially additives, can cause problems. If the properties of the oil are different, it may seep past the seal. This is what you typically see with synthetic oils. It doesn’t really damage the seal, it just can’t hold back the synthetic oil.
The bigger issue is the compatibility with the seal material. This is particularly an issue with aftermarket additives. They may not be compatible with the seal material and degrade the seal over time. In fact, some additives are designed to swell seals to give a short term leak fix. The seal is likely to fail totally at some point. Also, the swelled seal will put more load on the machined sealing surface and can, over time, increase the wear on that surface.
Synthetic oils will give you benefits if you are using the vehicle under very sever conditions such as racing or frequent and prolonged towing but for everyday use, forget it. It also may have some benefit to hide minor wear issues in something like a transmission, but it may also leak.
- Pete
