I have a guys PS Audio 200cx that makes loud speaker pops and bumps when powered on and off.
I haven't checked the actual complaint but I think I see it on the DMM when checking the DC Balance.
The servo circuit is new to me and there's plenty of info in the web about it.
But:
The scats for the amp are hand drawn and missing the servo board. Reading the threads it seems PS Audio is tight with the service info.
I can make out most of the circuit and see the relationship to the servo from described web searches.
Now, How do I deal with this?
I'm thinking I have to disconnect the servo to make any DC Balance adjustments.(?)
I noticed that once the amp is warmed up the balance trimmer has no effect.
I also think I might have a bad servo amp. The servo is a separate board with an op-amp and simple circuit. The harness has four wires and is soldered to the bottom of the amp channels boards.
Note:
This amp has no protection or muting relay. Only a power on and off relay.
Below is the main amp schematic. It's all I could find so-far. No servo circuit but the output is seen near the pre stage.
But:
Note:
