OLAs Most Difficult Speaker Refoam to Date
macaltec
Metal Master
I have been re-foaming speakers since I found AK in 2004. I have done so many pairs over the years I have lost count. I recently acquired a set of OLAs that didn't have the masonite ring woofers (I have re-foamed several of them) and missing the original tweeters. I figured I would get the woofers sorted and then hunt for some tweeters later. Not for lack of effort (I have done several of these as well) but I cannot get the 1st woofer foamed without getting VC rub. I feel like the spider may have become distorted over time as the foam attaches to the woofer cone, but not the basket does not sit flush all the way around. Like the whole cone assembly is off axis with regard to the magnet assembly. Anyone else ever had this issue? Are recone parts available anywhere?
Only refoamed one set of NLA and had no rubbing problems. Are you doing it with the 30 Hz signal? I did a Cerwin with VC rub and used clothes pins to hold it in place while the outer glue dried and was able to cock the woofer enough that it doesn't rub and works great. Foam looks a bit odd with one side narrower and higher than the other, but it's not really noticeable.
Yup 20Hz and/or white noise. Manipulated the surround to pull it enough to not get a VC rub. It is ok but not right. This is not the first problematic woofer I have encountered just the most stubborn. Curious if there are options available to rebuild it myself???
:needpics:
So what are you refoaming? The woofers that came with the OLA but are not the correct ones? Or the replacement OLA woofers?
They are the woofers that were in the OLAs when I got them. I don't recall the OLAs coming with a woofer without the masonite ring but who knows. So for all intents and purposes let's call them NLA woofers.
I used to do the shims a long time ago. Got tired of cutting dustcaps off. First time I've ever had a problem.
Hmmm. I am confused. You are asking for advice related to problems you are experiencing with a particular driver. But you don't want to provide specifics as to what driver is actually in there?
I have a pair of OLA and they have the masonite woofers. As far as I've heard, that is the only type of woofer that came in the OLA. I have a pair of Advent/1s with the NLA woofer. It is a vastly different construction. I also have a pair of NLA with frankenwoofers in them. They have the original baskets but they were obviously reconed with something different.
For all we know, you have frankendrivers.
You think the spider may be deformed. Well, show us or all we can do is guess. Basically, all we know is you have some kind of driver in there with some kind of problem.
They are Advent woofers, without a masonite ring. They certainly would have been found in NLAs. I suppose it's possible that the OLAs may have had some installed toward the end of their life span or someone had replaced them some time ago. Whether they are original to the OLA cabinets or not I have no idea. I know what I have, this is not my first rodeo, sorry for not being blatantly obvious.
I do every single one with shims. Guarantees perfect, concentric gaps every time. So no, never had a failure with the 6 sets of Advents or any other model.
It takes less than 10 seconds to cut the dust cap off and maybe 45 seconds to apply glue, set in a new dust cap, and set a large socket on top till it dries. Longer on JBL’s when your using dust caps without lips and need to apply a nice bead of the black adhesive but the value of the woofer is worth the effort.
It’s a bummer your having an issue though.
I did not take pictures and the foam is now installed. I am asking more to the fact that the spiders could have sagged or become distorted. Also asking if anyone may have encountered a rebuild kit, of sorts for the Advent woofers?
Yeah, doing with a test tone is the best alternative. Do what works best. There are lots of us who don't do anything at all and have had success. I don't get that at all, you may get an adequate result but seldom perfect.
In this case shim it and see if it shifts after you pull the shims out. That should tell you if the spyder is the problem.
It stayed centered fine until I got the foam onto the cone and one side of the outer edge was resting on the basket and 180° from it the foam edge was off the basket by about 1/16". Imagine the pole piece of the magnet being perfectly plum and the VC tilted to a small degree. I have heard of spiders and cones sagging, this my first encounter with the possibility.
Naturally when I pulled the portion of the foam down to meet the basket it pulled the VC enough to make it rub.
Is there a possibility the paper cone is not cut correctly? With no surround is the gap equal, all the way around? Is one side higher or lower?
I encountered the same problem many times. Since you have previously cut dust caps and shimmed I would go that route if worried. The outer edge of the surround's may not look quite centered, but if you shim them they should be fine. As far as a rebuild kit goes, I have not seen one readily available, but I may be able to find out. My vote is to shim. Best of luck!
Look like mismatched woofers and like you said the wrong tweeters. So at this point I would be looking for some beat-up Utility models and switch the drivers over. You have the nice cabs.
Or not if you are stubborn ;)
How long did you leave the signal generator on them while they dried? I leave it on very low volume for a few hours.
I’ve done a dozen or so of the Avents, both Masonite ring and the metal basket, never had an issue.
I’ve also never cut a dustcap in any speaker I have re-foamed with the exception of a re-cone.
The gap was fine with a signal applied to center it. There was nothing visually out of alignment before I started to attach the foam. With the shape of the basket any small difference in between the plane of the basket and cone would be very difficult to see.
