Hi,
I have lp12+grace g707 tonearm(eff. mass-7g).
I wonder if the dynavector will be a good match for the grace,is the dyna high compliance? i read that the combination lp12+ekos+dyna karat is bass light.but linn at 1979-1980 used supex mc on the grace!
Please your rcommendation for the above combo,if no,which cart. mm or mc at the same level more or less as the dyna will be a good and dynamic match with the grace?
info-Dynavector Karat Ruby
Type: Very small size moving coil
Output voltage: 0.2mV / 1kHz / 5cm/sec
Frequency response: 20 to 50,000 Hz
Channel balance: 1dB (1kHz)
Channel separation: 20dB (1kHz)
Compliance: 15cu
Impedance: R = 30 ohms, L = 80 microhenry
Stylus: 0.1mm x 0.1mm, line contact naked diamond
Cantilever: 0.4mm x 0.4mm x 2.5mm, oblique cut solid ruby
Vertical tracking angle: 20-degrees
Tracking force: 1.5g +1.0g –0.3g
Height: 17.5mm
Weight: 5.3g
CHEERS.
Compliance: 15cu
Height: 17.5mm
Weight: 5.3g
CHEERS.
