I found this in my Brother in law's cellar, so I cleaned it and gave it a coat of paint, the contacts have tarnished a bit since then, as that was about 8 years ago.I just thought it was nice, any love for this kind of thing?Thats pretty cool,, is one side hot and the other neutral in the UK?,,, Looks like they just replace the fusible wire in the fuse blocks,, I guess using a piece of copper would be akin to putting a penny in the fuse box over here!!
Yep, that's right Hot and Neutral or 'Live' and 'Neutral' as more commonly said over here.![]()
Is it just dependent on the pipe/conduit ?
I'm not an expert, but I can tell you what I know- there has to be a correctly rated earth conductor running through the conduit, (which must also be earthed). The conduit itself must never be the only method of providing an earth path to circuit breakers/fuse boxes/mains outlets etc.
I didn't see a ground/earth lug in your panel....
