Never an issue after seven years with MC240 and plenty of others. I think the "crowbar" issue is a bit exaggerated... unless using garden hose size speaker cable.
Nice Gen IV MC240 @62caddy
Mine also has the S/N stamped partially on the bend / slightly off-square, I have never seen another like it until now.
Is this yours?
Where can I buy these?
For old amps like the MC2205, what's the best and most convenient way to connect speaker cables?
I am currently using these: Banana to Spade Adapter Plug/Speaker Cable Connector. I found prices vary from very cheap to expensive. Do I need to buy copper? Gold plated? Would the material matters much?
I have used these and my experience is that they will break before they could cause leverage problems. Despite the gold plating, they seem to be made of really soft, crappy metal. I just soldered some spades onto my cables. Much better solution.
That’s just silliness, considering the 20-22AWG wire on the other side of the rear panel …I tried using those on my Fisher 800B speaker terminals and did not like them. They were too wide, necessitating screws with a wider footprint. In order to insure they didn't loosen and cause a short, I covered them with shrink wrap. I eventually went with proper spade terminals soldered
directly to the speaker wire.
The photo. That little corroded black lead to the left goes to the other side of the (+) terminal on the speaker output strip.What part about my response is silly? Please elaborate.
Yeah but.... Where can these solder type spades be sourced? And hopefully they can accept decent gauge wire.
A specific link would be great. I haven't had luck searching for these.
I just use uninsulated crimp types, and add my own solder and heat shrink (they are both crimped and soldered)
I have absolutely no use whatsoever for banana plugs as speaker connectors. All of my systems are tube-type, and the loss of the load can easily fry an output transformer. I use heavy ring terminals soldered to the speaker cables. They are readily available for all terminal sizes and wire gauges.
