Old Sony Monsters SS-3300
There's a pair of these on the DC CL for 150.
I've seen them, they are in excellent condition.
No affil, etc.
Coral tweeters. Quite common, used in the Sansui SP line. You should be able to find a replacement.
I love my pair of these speakers. I've been colle ting spare drivers where I can, and in my research I've figured out what the drivers were. Posting here for posterity in case anyone needs to track down spares.
12“ woofers are a paper accordion surround variant of the 16ohm Pioneer PW30F
6" mid is another Pioneer PM12a
Tweeters are a Coral-made variant with slightly larger magnet structure of the T-200 tweeter used in a couple Sansui speakers. I use the sansui version in mine since the originals seem to be very fragile.
Resurrecting a very old thread.!. I've been holding onto a pair of these speakers for a long while and finally got around to putting them in my system.. they are very good! Going to tweak with the crossovers a bit.. Anyone else have long term results with crossover cap replacement? Going to do it is phases.. may bypass the crossover selector switch first as I will never tri-amp these.. anyone do that? Then I'll start with the tweeter caps. I really do think these are worthy
I replaced the caps in my pair with good results. I also bypassed the tri-amp switch at some point, but it's been too long to recall if it made any difference.
Great! Do you remember what brand of caps you used? I just went with Dayton 1% for the 1.8uf and Jantzens for the 4.7uf.. see how that goes... Also.. I have some nice REL caps that are 8.5uf to go in the where there's 8.8uf.. should be close enough? I'm going to leave the tri-amp switch alone for now..
Thanks for your reply!
I think I used Daytons for all of them. I left the original caps in place and just mounted the new ones close by with zip tie mounts.
bberkom! I finally got around to recapping the crossovers on the Sony's! I had some high quality REL caps for the biggest value and the rest I went with 1% Daytons..and cross caps for the 1.8uf So far I'm impressed! only have maybe 20 hours on them so.. I think they will only get better! I may go with some clarity caps for the tweeters in the future.. I've had great luck with clarity caps
