Old Technics amp gain has gone mental after changing some parts
Anolsos_1974
Hi all, it’s a technics su c04. The volume pot was shot so I swapped it for the same spec pot. Stupidly I didn’t keep track and after replacing some bad caps (the two main caps, and the one in the power supply) I noticed the gain on the main volume knob has jumped - now it reaches full volume in about one quarter turn of the volume control. My limited experience is wondering if there is a mistake with the resistance of the VR as I had a similar experience replacing VRs in old speakers where I couldn’t find the exact spec VR so all the recognisable change in respective driver volume occurred in a half turn rather than a full turn, if that makes sense.
I don’t want to waste anyone’s time but if there is something obvious I’m doing wrong I would appreciate it!
I attach two pictures, the second shows heat damage around the power supply section which prompted the change of that capacitor
Did you replace an original audio taper (log taper) pot with a linear taper one?
The full throttle at 1/4 turn is a classic symptom of this.
Good luck!
Yes I have this! Long discontinued unfortunately. I have a number of a uk company that does audio stuff so they might have something. I guess linear pots are what most folk need.
So the pot is a linear taper one? Then the issue is elsewhere.
I would start by making sure all the wiring to and from the pot is correct.
Good luck!
In general, most volume controls are audio (logarithmic) pots. When you substitute a linear pot for an audio pot, you get a super-sensitive control that maxes out at 10 O'Clock.
I didn’t know this so thank you. I’m trying to learn on this less important amp so I don’t make the mistakes on my proper amp which has similar, and intermittent faults
See my edited post. I believe you have a linear pot. So, the issue lies elsewhere. Sorry!
Have you downloaded the Service Manual? That is a complicated unit. Good luck!
:thumbsup:
Hello again,
Hello, yes according to the service guide it is a linear pot so the issue lies elsewhere! Strange though because the previous one was just crackling and popping
Hi, I just put back the original volume pot (which according to the service guide is linear as you mentioned) and the volume works normally again - so is the guide wrong? When i stick a voltmeter on the terminals of both VRs they both look linear. Are there different types of linear?!
I also tried adjusting the dc balance to get 2mV (as specified in the service guide) but the voltage was jumping all over the place. I thought bad pots there maybe so replaced them both but it made no difference - could these two be related?
I also replaced pretty much all the electrolytic capacitors as I had already ordered them. I am actually sat listening to the amp and it sounds ok so I think I am getting somewhere!
But if you have any idea about these niggles I would love to hear!
Hello again,
Thanks for the update!
No, I believe that Technics designed the volume circuit to have a LINEAR pot. While a majority of manufacturers design circuits to use AUDIO (or logarithmic) volume pots, this is not 100% true.
the letter codes for linear vs log are different on Japanese vs US gear. I don't happen to know what the Euro standard is. a US "A" pot is audio/log, in Japan thats linear. US B pots are linear, in Japan thats audio/log.
either way its not real difficult to figure it out if its at all functional. Put the pot at mid travel and measure from each end to the wiper. A linear pot will be half the resistance from either end to wiper, +/- how accurately you set the pot. A log pot will be roughly 85% pot value from one end to center and 15% from the other end. The exact value varies somewhere between about 80/20 and 90/10 but its very obviously not 50/50.
