Also, as noted above, a replicated, pressed audio CD meets the strictest guidelines for formatting and pit structure. The TOC info is located in the correct Lead-In locations, Time Code that doesn't shift or jump, and data that is easier to read, since the pits are pressed/stamped into the polycarbonate structure, and not burned. This makes a replicated CD much easier to be universally read.
Early CD-R & CD-RW burning was a bit of a crap shoot, much dependent of the PC drive used to burn the CD-R, the formatting software, the burning software, the CD-R blanks, and the method of burning. Slow burning speeds work best for an audio CD-R, since there is no redundant data on audio discs, unlike Rom discs. ROM formatting, under a certain size, allowed for redundant data, to be written in adjacent sectors, to allow the PC playback drive to hunt for the data, if a disc sector was corrupted in one area, and readable in another. Audio never had this feature, which higher speed burning of pits, made worse.
