Mark Davis
Ok on my on the new estate sale Fisher 400 Serial # 34129S.
I have noticed the volume knob is different from my 1st Early 400 Serial # 15350E.
I thought it might have been replaced as the little notch/tab on the on off knob lined up at 1:00 in the off position instead of 7:00.
I would like the notch/tab to be at 7:00 like it is supposed to be
The knob can only go one way unless I am a idiot.
I have not tried rotating the whole knob. I am wondering if the wires will reach or if rotated the tabs will short to the chassis.
Has anyone seen this type of switch with the long wire connections? I assume it is a replacement, I don't know if it works as I am waiting on new can caps from Hayseed.
I know that the on off switch is notorious for failure. Has anyone found a solution for a replacement?
Thanks in Advance
Thanks in Advance
