Rudy81
Member
I have decided to tackle this much discussed topic yet again since I seem to be slower than most and just didn't get it. I hope this topic will help another Khorn owner who may have taken the recommendations with a grain of salt.
I purchased my Khorns, used, almost three years ago. Until then I had Belles and La Scalas. I was very familiar with the bass they could produce, but was new to the Khorn. I appealed for help on the forum after first setting up the Khorns since they seemed to have considerably less bass than did my Belles or LaS. Everyone chimed in and said, "make sure the bass bin is sealed well" against the wall. I eventually built a nice set of very heavy and very sturdy false corners since my room has some limitations at the corners, and I wanted the ability to turn the Khorns and move the sweet spot further back. These corners worked very well and I did what I thought was a good job of "sealing" the tailboards. The bass did improve considerably, but I did, on occassion need my sub to supplement the Khorns when listening to bass intensive music. I use my system for both 2-channel listening and 7.1 channel movies. Overall, I was satisified, but always wondered why the bass on the Khorns was not quite as punchy as my Belles or LaS.
I recently stumbled upon this thread http://forums.klipsch.com/forums/thread/831251.aspx concerning sealing the backs to mirror the look of the anniversary Khorns that come with sealed backs. I originally thought I would try to do this surgical procedure. However, after researching some old Dope from Hope articles, and many threads on this forum, I came to the conclusion that a properly sealed Khorns would sound as good or better than the surgically altered "sealed" model....which, would be a time consuming undertaking not to mention putting holes in my bass bins. So, I opted instead to make sure that my Khorns were properly sealed.
While working with my false corners and a flashlight, I noticed that light was leaking along parts of the tail boards. I had stuck the flashlight near the very corner and could see some light escaping from the front side of the tail board. ???? My thought was that I had not done a good job of sealing the Khorns, and certailnly if light can escape, so could air pressure waves. I decided to use the pipe insulation others have mentioned on this forum in order to ensure and tight seal and to allow for the imperfections on my corners to be filled. After re-sealing the Khorns and ensuring light did not get through the seal, I set my system back up.
This is the part that kills me. I should have done this from the start, two plus years ago!!!!! I had no idea the Khorns could go this low! Just for fun I turned on my sub as I used to before, and I could not tell if it was on or not. The bass is out of this world and has made everything I listen to that much better, more fuller and complete.
Bottom line, I was stupid for not taking this sealing thing more seriously and ensuring I had a darn near perfect seal. The difference is simply dramatic. I thought I would re-visit the topic in case there is another poor soul with these magnificent speakers that is missing out on what they can do.
My thanks to those who contributed to this issue in so many other threads.
It doesn’t even need corners!
