I have an Onkyo A-9010 integrated amplifier(non-UK model with digital inputs) and it's worked well for the ~2 years I've had it. Recently, the digital inputs(both Coaxial and Optical from different sources) stopped working correctly. If I turn the volume up to 100%, then I can hear the audio feebly. The headphone output(from digital source) works correctly at all volumes. Analog inputs also work as expected.
I took a quick look inside and couldn't immediately spot any blown capacitors. It's out of warranty and I do not have a service centre here that I can use(this was an imported unit).
Any idea what could be wrong and how I could go about diagnosing this? I'm happy to post pictures if required and I'm also pretty handy with a soldering iron.
Thanks!
Thanks!
