Onkyo CP-1044F not much info out there
Hula Daddy
I have a line on an Onkyo CP-1044F for a good price. I really cant find much info out there other then Vinylengine. The specs are respectable and seem to be better then my Marantz 6200
Any thoughts on if this would be an upgrade? I definitely does not look as cool as my Marantz, but wow and flutter semm to be significant and it is direct drive.
http://www.vinylengine.com/library/onkyo/cp-1044f.shtml
Specifications
Type: quartz locked direct drive fully automatic
Platter: 310mm aluminium diecast
Motor: brushless dc quartz direct drive
Speeds: 33 and 45rpm
Wow and flutter: 0.025% wrms
Signal to noise ratio: 75dB
Tonearm: static balanced straight type
Effective length: 224mm
Overhang: 13mm
Cartridge weight range: 5 to 9g
Dimensions: 418 x 376 x 132mm
Weight: 6.0kg
I had a CP-1500F that looked very similar. It had some kind of strange bearing that just collapsed for no reason and I ended up trashing it. Mine was BPC. It seemed to be cheaply made. But I don't have any experience with the 1044F directly. You may have a total different experience.
