chris_zeel
I have a nice TA-2700 deck that I bought a while ago. The seller mentioned that the belts were replaced not so long ago and in principe it plays well. Speed seemed to be good and stable upon listening. Forwarding and rewinding also worked fine.
After not using it for while I connected it again and some playing issues started.
What happens is that after playing for about half a minute the right hub stops spinning and one or two seconds later the deck stops. When I take the cassette out there is a short loop of tape sticking out. After winding the tape back into the cassette and placing it back in the deck it will not play, forward or rewind. It will play, forward and reverse again when I turn the hubs back and forth a little by hand before putting the tape back in.
I have cleaned the capstan and pinch roller with IPA.
What could be the issues? Bad belts after all?
What other tests can I do to find out more about what the culprit is?
Thanks for thinking with me!
