onkyo TX-2500/lamp values
jkcoondog3
I see there are several Onkyo owners out there and I need to know the lamp values for a TX-2500. The small lamps that light up the stereo, locked and tuned indicators. Can't seem to find anything in the service manual. Only fuse lamp values which are 6.3v 0.25amp. Anyone know? Could use some help. thanks
stick a volt meter on the output at the source will get us in the ball park. Pics helps, too. Check to see if the bulb is removable pin type.. etc..
I posted that replacing bulbs is becoming a hens teeth search. So be prepared to modify.
