I bought a 2nd TX-2500 for the faceplate glass and the bonnet. It looks so pristine I don't want to use it as a parts unit. As advertised it does not power up. All 4 fuses test good as does the power cord. I tried cleaning the power switch with deoxit and used a jumper wire between the two wires attached to the power switch. No go. I removed the jumper wire and verified that I have 120 VAC at the two wires connected to the power switch. However, when I engage the power switch that drops to either 0.022 VAC or 5.022 VAC. There's no relay, but I'm guessing some sort of protection circuit is doing that. Any ideas as to where to look?
