Blue Shadow
Waiting for Vintage Gear from this century
This Onkyo TX-3000 has a burned out lamp for the Tuned Indicator. All other lamps work except the dial indicator which I replaced.
Investigating the Tuned Indicator, the lamp should light when the tuning knob is released and the unit is on the station.
The Stereo Lamp for stereo stations, the Locked Lamp for the stations within locking range on the dial both light but releasing the knob did not light the tuned lamp. Investigations indicate the lamp is receiving about 20 volts whenever the unit is on. The voltage drops when the tuning knob is touched so I'm guessing that sensor is working. Does this in all three settings for the sensor sensitivity.
The SM is on HFE: https://www.hifiengine.com/manual_library/onkyo/tx-3000.shtml
Lamp receives voltage on all inputs when the unit is on. The tuned lamp is under the tuning meter just to the left of the transformer.
