There are 2 220 Ohm resistors in series with the output so capacitive loads should not be an issue. Both opamps should work fine.
That PC scope is sure better than nothing. The spec you are interested in is the sampling rate, measured in mega samples/second. Divide by three (roughly) to get the useful bandwidth.
Found this: The Hantek 6022BE is a USB-based, 2-channel oscilloscope with an analog bandwidth of 20MS/s and 48MS/s sampling rate. So it sounds fast enough, just need a capable operator![]()
Thanks for the heads up, guys. I’ll add a used Tektronix to my shopping list. A quick C.L. check didn’t find any locally, HP and some others. May have to go to the Bay...
I have the same model. Great scope, love the measurement functions!I’ve have a Tek 2252 and it is a great ‘scope. 100 MHz 4 channel analog. If you enjoy this stuff it is indispensable.![]()
Try your local ham radio club.
Interesting suggestion. My first reaction was, right, like those still exist. Then I Googled local clubs and wow, there's a lot of activity in my area. I missed the big annual swap meet but I'm sure there are others or maybe I can post on one of their sites. Thanks!
You're welcome.
Yeah, hams actually still do exist. Who do you think is going to run communications after the Zombie Apocalypse. The hams will have figured out how to get the generators going, the radio antennas up, the transmitters and receivers humming away. Then they'll all get eaten by the zombies because old guys can't run fast.
Just go to a meeting and explain what you're looking for. Everyone knows everyone else in those small communities.
