I just finished a full recap on a Sony 508ESD CD player and had so much fun that I'd like to try an Op Amp upgrade that I read about in a very old post elsewhere on the interweb. The TI OPA2134 looks like an easy drop-in replacement for the original NJM4580D, but what has me puzzled is the advise I found on upgrading the power supply caps for the OPA2134s. The advice was:
..great results running OPA2134's with at least 470uf Nichicon & 0.47uf PP film directly from each chip's supply pins to ground. Going from 220uf to 470uf with generous film cap bypassing really brought the bass into 'full reality' and gave the whole picture much more depth of tone. (edited)
I see (3) 220uF caps in the power supply circuit: C378 and C379 in the OPA vicinity, C378 goes from +5v to gnd, C379 goes from -5v to gnd. Then C920 from -16v? to gnd near the power supply area of the board - I assume this one is not in play.
Would the recommendation be to replace the 220uF C378 and C379 caps with 470uF and PP bypass caps? Or to leave the 220uFs and add (2) off-board 470uF caps: one with the "+" lead wired directly to the V+ pins on the OPAs and the "-" lead to gnd; then the other with the "-" lead wired directly to the V- pins on the OPAs and the "+" lead to gnd? This probably sounds like a stupid question to someone who knows what they're doing, but it's not clear to me
. Thanks for any help!
Sony CDP 508ESD Schematic
