Poultrygeist
Lunatic Member
I believe you are operating under a few misconceptions about PP amps.
cheers,
Douglas
Here's a good article for you to read.
http://www.decware.com/paper43.htm
cheers,
Douglas
My 93 db BL horns powered by a 2a3 SET can play painfully loud.
Oh yes, I am quite familiar with that sort of 'take' on SE. And his amps.
Fast-forward 15 years and his top four amps are all push-pull....
Are you looking to build or buy it?
Just to be clear: that's a marketing document NOT a technical article.
Personally, my goal right now is to design and build a PP amp that has all the transparency of my two stage direct coupled 300B SET. I have tried with several PP 6P14P-EV amps that just don't make it, but I am now attempting a PP 6V6 amp and a PP 6A5G amp. Only time will tell....
He wasn't selling any PP amps when he wrote it.Doesn't help Steve sell his push pulls does it?
Because it's marketing for his SE amps, as Pak said above, also a business decision. I've had a Decware SE amp for a long time, it's a good amp and works well with my Altecs. I'm familiar with Steve as well. I can't say I've experienced the horrors of PP as described by Steve, in fact my 60yo PP monoblocks provide a more satisfying experience overall for my taste and the Decware amp lives in its box. Certainly it does some things very well, better than my PP amps, but with the experience of hearing a number of amps over the years I can recognize that Steve's white papers are largely enthusiastic marketing.Makes you wonder why it's still there then? Selling PP amps for Steve was a business decision. I know the guy.
That's a couple of generations after the original and "B" models, but of course he likes his products and is proud of them. Fifteen years ago he wasn't saying that was his best amp and I'm sure he's not saying the same thing about PP as a topology now as he was back then. I'm going to go out on a limb and guess that he thinks his PP amps are better than others', but what exactly are we arguing here?![]()
Decware started with this and it's still Steve's favorite.
As Joe said, it is all in what you use to build it, and in what path the electrons flow
Negative feedback does not give you higher power, it gives you less gain, and most importantly, lower distortion.Stick with a SET which unlike most push pull amps they don't employ negative feedback to gain higher power.
