Optimus 1 Tweeters
citymech
I recently picked up a pair of really nice Optimus 1 speakers for a song, but discovered 1 of them has an open tweeter. These use the same 0705AE 16 ohm tweeters as the Nova 7B. I haven't been able to find OE replacements, so I began looking for suitable substitutes. I found a 16 ohm 2-½" full range driver at Parts Express. Can I use full range drivers in place of tweeters?
https://www.parts-express.com/Dayto...gnesium-Cone-Full-Range-Driver-16-Ohm-295-519
If your Optimus-1's have 0705Ae in them then the originals had been replaced. 0705Ae are found in both Optimus-1B and Nova-7B, which were promoted as having improved mid/tweeters when they appeared in 1975:
They do make excellent replacements for use in Optimus-1. Unfortunate that they're becoming scarce.
Those would probably work performance-wise. Individual sensitivity is a bit low, but the 6dB gain from using 2 in parallel should put it in the ballpark.
Mounting could pose a challenge. Opening in the wood baffle is about 73mm. ND64-16 mounting screw holes are inside of that, centered on 66mm diameter.
You would need to fabricate a mounting plate or otherwise modify the baffle.
Another option is to substitute a pair of 4Ω full range wired in series. There would be no dB gain so replacements should have suitable sensitivity to balance with the woofer.
Just thought I'd mention there's a 0705Ae listed on ebay right now (no affiliation). The seller has it listed as an "Optimus 5B Tweeter", clearly not understanding there are no 16Ω drivers in that speaker model.
16 ohm tweeters were used in a few models. The 1's, not the 1B's may be one of them
The models that I'm aware of -- all 2-way systems -- using pairs of 16Ω wide-range mid/tweeters wired in parallel are:
Optimus-4
Optimus-1
Optimus-1B
Nova-7B
Optimus-17 (not marketed in North America).
Optimus-1 (and Optimus-4 apparently) have had mid/tweeter model changes during their production runs, with the earliest having alnico magnets. Any of of the above could be considered for substitutes when exact model can't be located.
Optimus-21 4Ω mid/tweeters (0738) could work in a pinch, failing availability of all else. They have the exact same form factor and wide-range bandwidth, with power handling from the aluminium voice coil era. Just wire them in series.
