does it go into record mode ?
Pete--so, I powered-up the deck last night just to test it once again and to get more information to work with (and from). So, here's what I found:
-Deck powers-up just fine. All of the lights are working, etc.
-I placed a pre-recorded cassette in it; push the "play" button and it sounded just fantastic.
-I then tested both the Reverse and Fast Forward functions (regular and APSS) and these, again worked just fine.
-I then place a blank tape in the machine; ran through all of these functions again to ensure that the tape wasn't the problem and, again, it worked well.
-I turned off the Play Mode so the deck was idle; pressed the "RECORD" button; it sounded like the "Recording Heads" engaged (that nice little "thump" that it makes when it goes into "RECORD/PAUSE MODE") and then the deck proceeded to make an ugly "grinding noise"--similar to the sound you would hear if the cassette not placed in the deck properly. The tape itself was not moving; none of the other functions would work and I the "STOP" function would not stop this nauseating sound from continuing. I had to turn off the deck completely; let it rest for a few minutes, turn it back on and then this noise would stop. Oddly enough, even after I turned the power off, the cassette door would not open (again, as if the cassette were jammed in the machine or somehow engaged in a function during which one would not try to eject the tape).
-I repeated this process a number of times before I finally surrendered; turned-off the deck and then went to bed for the night.
-By the way, the I have maintained the deck very well over the years; regularly cleaned the heads and tape transport mechanisms; kept the rubber transport wheels intact and in great condition (everything is still original to the deck--the transport wheels have not deteriorated into 'mush', etc.)
So, let me know if this information is helpful and if you think that cleaning the Record Switch would do any good or if you have some other ideas that may be of help.....(This deck sounds too good to give-up on it...plus, like I said, I paid $385.00 for it back in 1981 when I was making $4.00 an hour as a darkroom technician).
Thanks Much--Joe In Minneapolis
