lawyerjim47
Found a real nice Optonica RT-6505. Belts (main and tape counter) are a bit loose, but still turn parts as intended when I turn them by hand. There is a small idler tire that is still solid and makes contact. There is a fuse, but it is fine, and all lights turn on except the one behind the tape. However, I cannot get the motor to turn on. When I hit play/rw/ff, the switches stay down for a couple of seconds (like when the tape ends), and then pop back into place. The spindle on the motor can be easily turned, and while it is hooked up to a circuit board, there are only two lines going out so nothing seemingly electronically weird.
Checked the power board but nothing looks iffy. (That is about the extent of my electronics knowledge).
Question: motor dead or something else?
Thanks,
Jim
Thanks,
Jim
