meewoo
Hi, Vintage gurus, I got a Optonica SA-4141 but found out that left channel leaks very loud sound even I turned sound to minimum. ( I already deoxided all pots and controllers). Only way to use receiver is to turn the balance all the way to right, than turn the sound a little, turn the balance back to left a little, sound a little, balance a little. So if I want to turn the volume, I need to adjust balance simultaneously. Do you guys know how to fix it? (I didn't do DC off set) Thanks in advance!!
