Wray & Ting
Member
This is a happier thread than I thought I was going to be starting when I woke up this morning. My Optonica SM-3636 that I've owned for about 3 years went into protection mode while idle last week. For several months leading up to that, it had been intermittently emitting very loud bursts of noise when powered on that had me worried for my speakers, but it was so random and infrequent I just ignored it for the most part. The instant before it died last week it gave one of those loud bursts, so they must be related.
I had the amp opened up today and was measuring some voltages on the right channel board while it was in protection, when I heard the relay switch, but the light stayed red. I continued taking measurements (TP402 and TP404, both zero VDC compared to TP401 and TP403 which were both -27 VDC), and the relay switched again, this time lighting the happy green light! I powered the unit off and on again, and the LED went green after the usual 4 seconds just like it should. Am I probably correct in assuming there is a loose connection or cold solder joint on the right channel board that may be the culprit behind both the noise and the recent protection mode? It seems my multimeter probing might have flexed the board enough to reestablish a connection.
If I can't find any suspect solder, should I just resolder anything I see that makes me look twice? Aside from a needed recap (and the electrolytics are all original, even the power caps) is there anything else I should do as preventive maintenance going forward? As a final note, there is some evidence of previous repair inside and the unit differs a bit from the schematic available on HFE. Mine has 3x 120 V plugins on the back instead of a fuse, there is no voltage selector switch on the back, only one fuse per monoblock, and no other fuses inside, and the high voltage capacitor on the power switch is a different type than what I see online.
