Original C22 Balance Issue
Pyfite
Hey there Eveyone
I've got a vintage McIntosh C22 issue that just popped up and I'm hoping sounds familiar to someone who's fixed such a thing. The issue is I'm getting barely any right channel output until the balance knob is around 3 o'clock. If I switch the outputs same thing happens with the left channel. If I sum up L/R I get barely anything (slight crackle and output) until, again, the balance knob is at the 3 o'clock position.
I've:
Switched tubes
Switched outputs
Switched inputs
Fader F5 on the balance balance knob/part
Tapped the balance section and noticed a slight increase in volume (maybe 10%) on the right channel output (before 3)
All did not solve the problem. Any ideas before I send this off to repair camp for a couple months?
Thanks in advance!
JK
I'm currently working on this very same problem. I removed and dismantled the balance control. What I found inside was surprising....I have never encountered this before. The carbon trace had detached itself! So, no way to repair this. The pot needs to be replaced. Measuring across the good gang, I measure 375k ohms. According to one schematic I downloaded, it says 500k ohms. Then I downloaded the service manual, and it indicates 50k ohms. So, which is correct? I would guess 500K since that is closer to what I measure.
I'm going to order this pot and see if it will work: Mouser part number 31VW505-F. The shaft is too short, and does not have a flat, so I will have to modify it. Last time I did something like this, I used an aluminum pipe, and using epoxy, glued the shaft from the original pot on the new pot. If I succeed, I'll come back here and let you all know how I did it. Or....is there an alternative? Is there an exact pot out there?
