yes, and easier to repair separate devicesTools that try to be too many things don't work for me. As with audio, separate devices are the way I go.
I'm good on flukes. Have 2 (I with amp clamp) in Ohio and 1 in Florida. I don't have a good quality analog multimeter, just a old realistic radio shack one. It's good for testing a sweep on potentiometers to see drop outs etc. but a scope would probably replace the analog meter. Thanks.Get an O-Scope made by Tektronix (mine is a 2205). You won't regret it. A 20MHz or higher bandwidth will be more than enough for audio. Tools that try to be too many things don't work for me. As with audio, separate devices are the way I go.
I'm using a Heathkit audio signal generator that I built in the early 1980's. Someone will have knowledge of current models and manufacturers.
If you don't have a multimeter get a Fluke. It's another purchase you won't regret.
Yes
I'd go with something a bit more traditionalCan anyone recommend a oscilloscope with signal generator for adjusting vintage stereo amplifiers etc. Looking to spend around $200.00 US .Thanks.
You can get a pretty good new scope for about $400 with probes, maybe a little less even. I have a Rigol DS1102E that works well. It was around $400 when I got it but looks like they're around $450 now. There are probably some better ones out there now though. I haven't kept up on all the new models.What does a new suitable scope cost? The tectronics on epay all are used and most are as is, or not tested and missing probes. Are they same as stereos and repairable with capacitor, resistors, diodes and transistors etc. Just rather save up and pay for new one, unless suitable ones are outrageous new. Looks like $200 bucks and probably another $200 for parts and testing probes if you go the used route. Just wondering. Thanks.
