Often when there are frequency response issues with a device under test you will read about the tech performing square wave testing; this is more efficient than injecting sine waves of various frequencies and seeing where the amplitude drops off. Usually a 400 Hz square wave is used.
As we look at a square wave on the oscilloscope we should see a perfect square, with steep leading and falling edges and a flat top, like this:
The flat top shows that the device under test has good low frequency response. If it did not, the top would not be flat. Loss of low end looks like this:
Note that while the leading and falling edges of the square wave are going straight up, the top is not flat... at all. If this was an amplifier, it would sound tinny.
At the other end of the spectrum we have poor high frequency response, which looks like this:
Notice how rounded the corners of the leading edge is; this amplifier would sound muffled.
Square wave testing is a great way to troubleshoot issues with tone controls, and as a quick test of overall frequency response. If you have a scope and a generator that outputs square waves, look at the output of a receiver or preamp as you move the bass and treble controls. It's a great way to get an idea of what good and bad square waves look like.
Edit: please note that your scope must be DC coupled for this test. AC coupling will distort your square wave, making you think there is a problem with low frequency response.
