I'm troubleshooting a weak FM tuner on a Pioneer SX-770 and have another working SX-770 available for comparison.
I'm trying to measure the 10.7 MHz IF output from the FM front end, at the point where it enters the IF board (W31-002, terminal 3, marked FM IN). My goal is simply to compare the signal level from the working receiver with the problem receiver and determine whether the loss is occurring in the front end.
I tried a FNIRSI 2C53P 50 MHz scope, but even on the working receiver I haven't been able to get a reliable, repeatable display of the IF signal. The lowest vertical setting I can get is about 10 mV/div using a 1X probe. I've confirmed the scope will display a known 2 MHz signal, so the scope itself appears to be functioning.
What type of oscilloscope/probe would you recommend for reliably viewing the 10.7 MHz IF signal at this point in the circuit? Is the issue likely to be scope sensitivity, probe loading, or am I approaching the measurement incorrectly?
I'm not trying to do a complete FM alignment at this point—just compare the front-end output of a known-good SX-770 with the weak one.
Thanks for any advice.
