ggizzy
EMI extraordinaire
Good afternoon,
I'm working on a four channel PA valve amp and am wrapping up the rewiring. The back of the chassis is not enclosed, with the OT sitting to one side and the output jacks at the other. The last bit of wiring I need to do is from the secondary on the OT to these speaker jacks, which also runs near the mains socket. There are three speaker jacks labeled 6ohm, 6ohm, and 15ohm.
If I run shielded wire from these jacks to the OT should I ground the shield at the jack itself or to chassis ground? Am I totally off here? Thanks.
