greenflash
Well I've been fighting with an issue with my computer to amp sound output.
In a previous thread I started (link at the bottom, thanks @Oldsansui441 ) I indicated that there was a noise/humming in my Akai amp, discovering that it would sort of go away after pressing the bass knob.
I did the cleaning up etc, took the amp elsewhere and it worked well.. I eventually put another amp which.. Ended up with the same noise.
I changed cables, speakers, disconnected stuff (deck etc) and finally went back to the Akai. Again, same thing.
So I realize that unplugging the miniplug->RCA from the computer and connecting a FIIO player instead would take away ALL hum/hiss etc (Didn't I try that before??). Crystal sound (so far at least).
I am using a fiio DAC with the computer. I also tried direct line out connection. Definitely the computer is the problem..
Do I need some kind of protection/isolation? Anybody had the same experience? Thanks!!
Previous post:
http://audiokarma.org/forums/index....0-noise-in-the-bass-knob.704328/#post-9454582
Previous post:
