Ultralinear was a trade name. A slogan, so to speak. It was owned by Herb Keroses company Acrosound. Hence the Acrosound Ultralinear transformers of global acclaim. I own a few examples as well as a few original catalogs. In terms of the "Ultralinear" trade name, no there were never any single ended examples. So that all came about when hobbiests stuck the "Ultralinear" trade name on their single ended amps.
Theres no right or wrong way of looking at it.
Putting the Ultralinear name on a single ended design seems in my opinion to be an attempt to capitalize on a cool name which once meant outstanding quality.
Theres a manufacturer who prints Ultralinear on speakers. Doesn't mean Herb approves.
Sorry for the derailment.
I can't help with any OT recommendations, but I gotta ask . . . since you just built a SE KT88 with a 5k "UL tapped" OT using the Edcors, why build an entirely new amp that seems to be essentially the same as the first one?I'm thinking about building another amp, and wondering who is still building the larger power transformers in 2021. Several of the manufacturers posted in the past seemed to have stopped production, and I'm not seeing a lot of options for exactly what I'm looking for, a 5K primary UL tapped SE capable of handling a KT88 @ 80ma safely with headroom. Edcor and Hammond are the two main ones, reading the big Hammond has some roll-off on the high end. I also see a 4.7K offering from Classic tone, not heard much about this 40-18080 model. I also see Electra-print is still making transformers and have a good reputation.
Anyway, just looking for some advice and to see what my options are.
Other than using different OTs what would be so different about this new build? If you're not satisfied with the Edcors, why not just replace them and tweak parts values if you want to try a different operating point? Or drop in a different tube in place of the 6EJ7?
I would suggest that, instead of building, you should consider setting up a breadboard. This allows you to experiment to your heart's content and, if you come up with something you like a lot, then you can build it.It's hard to compare changes without listening back to back is one reason. This is a hobby for me and I enjoy the building + is helping me from going crazy from COVID hibernationThis next one, I plan on using an 8 pin 6SN7 driver with various circuits, possibly as monoblock amps, but maybe I should just punch out this chassis and mod it? Or rewire it to try an pair of ECC85 / 6AQ8 tubes? Just exploring options and learning who is still making transformers in 2021 as my search pulled up conflicting info, some of it from a decade ago. Whatever I do, it sounds like some consensus that Electra-print is highly regarded. Maybe I should just venture off into a PP amp...
I have just gotten to tube rolling in this new amp and last night swapped in some soviet military 6Ж51П / 6J51P variants of the 6EJ7 and they sound a lot crisper/cleaner than the RCA mesh versions, but maybe a tad too bright? But maybe they just need to burn in some. I have some non-mesh GEs that are too microphonic, and a couple of other version to try out. Not sure exactly how many 6EJ7 variants there really are that aren't just rebranded of the same tube. There are other tube types I could try rolling in as well, but not sure any of these are sonically the equal of a good 6SN7? Trial and error I guess. I also want to try some EL34 tubes and I believe I can also roll in some 6V6GC, possibly needing minor mods. Maybe some combo of tubes will hit the magic balance for what I have already built. Like many things, it seems like the old story of the porridge is either too hot or too cold in search of audio nirvana
This is a deep rabbit hole I have ventured down, I appreciate your help and your question!
I agree with Kevin, although he's much more ambitious (and competent) than I am.Audiophile nervosa. Yup. It’s partly what keeps the big boys in business. Never being satisfied, endlessly upgrading...
For me, simpler is better, so I don’t play the game anymore. My thinking these days is I will only build a new amp if it explores a new concept I have not tried before. It’s not that interesting to me to build essentially the same thing again but with slightly different components. But to each their own....
That's a really good idea! Thanks.
I've been very happy with the Transcendar SE output transformers. I've used the chokes made by them also. The company is based in Holister Ca.Transcendar makes great transformers. I've used their SE transformers in a couple amps, and I think they're great.
Must have been due to me singing Transcendar praises on some other websites. Gery is retired, he stopped some years ago and when I found out at the end of 2019 that he was winding agian I immeditely ordered some custom made transformers. Late last year, when I heard about wanting to cut back I immediately ordered some more OPT. (plus fairful he might stop permanently or fall ill with Covid) Don't know what to do with those yet.... (better investment than tubes, still plnety of tubes available and made, but less and less good winders are available) Grab good transformers while you can. One electron look interesting to me, never had the opportunity to use those but nearly bought a pair.Unfortunately Transcender is no longer taking new orders. I got this message when I emailed them this past weekend:
"Due to an overwhelming backlog, we are unable to take on any more work at this time."
