Output transformer upgrade for Mag 9302- other tha n Edcor?
If your output transformers are set up with a 4 ohm output tap only, then you will get a little more power if you replace them with transformers with an output winding impedance that matches your speakers. But, the difference won't be all that much. What you will notice is that the overall frequency response should improve. Now, if you opt for higher 'HiFi" quality output transformers, the sound quality should improve even more. No power increase over a cheaper transformer with the proper output impedance, just sound quality improvement.
The design of many of these console amps is sound. Where they cut corners was in places like the output transformers. In fact, many specifically chose transformers and coupling capacitors so as to limit the deep bass. This was to help eliminate feedback through the turntable when playing records. Normally, if you use the power amp as a stand alone unit, the power transformer is more then up to the task since it was chosen not only to power the amp but also the preamp and, if so equipped, tuner. So, the power supply is generally well up to the task of powering just the power amp chassis. Put in a nice set of Hammond hifi transformers and that thing should really sing. The great thing about the hifi transformers Hammond produces is that they have 4, 8, and 16 ohm taps on their secondary winding so you can use most any speaker . Make sure you research the proper primary impedance you will need for the type of output tubes you are using. 6V6 and EL84 types like 8000 - 10,000 ohm transformers while 6L6, EL34 and 6550's prefer 4300 - 6600ohm transformers. Make sure the transformer is rated at or above the power output of the amp. These transformers are a bit larger then the OEM ones that come in console amps. But most of these amps have enough extra space on the chassis to handle slightly larger output transformers. I have done the output transformer upgrade to a console amp for a guy and the sound was amazing. Like night and day in comparison to the sound with the original transformers.
so which is better? going up in opt input Z over spec or down? And by how much? 1K? 500ohms?
suppose stock xfmr is 5700 Ohms Zin. No 5700 ohm trans to match it. Only 5000 or 6000. How to choose? Amp is 6bq5 SE
8K ohm is optimum for 6BQ5's PP , at 7.6K ohm slight increase in power but more distortion at 6.6 K ohm 7189 would be called for .At the other end the higher you go the less power out with out the problem of red plating
For a single 6BQ5 , the RCA tube manual says 4.5 k ohm for 5.7 watts and 10% distortion wired for pentode with the plate & sreen at 250 volts B+ . For less distortion go with 6K , more power 5K .
