mhardy6647
Lunatic Member
Bogen used some odd tubes in their consumer hifi amplifiers...
Did you mean 6P14P-EV (6П14П-EВ in Cyrillic) rather than the 6P15P-EV? They are similar but the 6P14P is the usual EL84 replacement. The 6P15P is lower power, lower limit values, etc.I'm with him... although I'd probably add 2A3!
I have yet to hear a bad sounding amp using the 6BQ5/EL84 - single-ended or push-pull; pentode or triode, Williamson or U/L...
The Russian "6p15p-ev" (6П15П-EВ in Cyrillic) tube is very nice sounding, inexpensive, and robust.
FWIW: I have several 7591 amps and receivers around here... I am still not totally sold on 'em... I've been told that there were some HH Scott power amps that used 7591s that are superb... but I've not experienced any of those to date.
For 6AV5 experience, you might want to look into the threads on the Bogen DB-130 and DB-230A amps for feedback on these tubes (generally very good). AKers Jon_S, Bricktop and Ab0eZ have done a good amount of work on these:6V6's are everywhere and cheap.
Can anyone add experiences with 6AV5 tubes? I have no idea what to do with the Bogen K030 monoblock that I picked up. It has 6AV5's, a high impedence input and a low impedence input with a step-up transformer, and I'm interested in what sounds I may get with it, particularly as a guitar amp.
Any suggestions?
I've read that 6FW5's (I think) are an upgrade from 6AV5's, and are generally an easy conversion.
Any thoughts on either 6AV5's or 6FW5's???
Your Heresys (Hereses? Heresii?) are efficient enough that you could probably go single ended with a couple of the tubes mentioned in this thread and be very happy with what you hear...I have been slipping away from the heavy rock of my youth and sliding into quieter jazz and soft rock. And at lower volumes. So I would like a smooth middle with a detailed base and not to tinny on the top.
Yes. :yes: The Kegger-designed SEUL 6BQ5 amps I built are the best I've heard from this family of tubes.6bq5
That'd do it, too.I'm with him... although I'd probably add 2A3!
I'd have to throw my lot in with the 6L6 family, for sheer bang-for-the-buck. IMHO, a 6550/KT88 can sound a LITTLE better, but the parts get much more expensive, quick.
A set of 6L6/5881/7581, with a Mullard-topology front end (i.e Eico HF22 or Harman-Kardon Citation V) can be something very special. Bass? You got it. Clean too.
There ain't a whole lot out there, IMHO, that will sound much better than a properly-set-up 6L6 Mullard-circuit amp. Only will get you between 20-40 watts per channel... but oh, what a GOOD sounding 20-40 watts that will be...
Regards,
Gordon.
EL84/6BQ5 for sweetness at low power, 6550/KT88 for more power but a certain sweetness in triode mode.
Oh, and I still have the Compactron amp to build. Can't wait to have that one up and running.
I have some plans to build an amp around the 6GH8/6BL8 and 6JC5/6JB5.
I could have written that! In fact, I'm sure I did several time before.I have some plans to build an amp around the 6GH8/6BL8 and 6JC5/6JB5. I want to build a couple of other things before I tackle it.
