NSRadio
Hello all,
TL;DR:
VM 1201 - If I hold the overarm up even just 1/16" as a record drops, then the tonearm will automatically swing into position and play the dropped record. If I do nothing and leave the overarm to rest on the record when it drops, the tonearm picks up, sets back down, and shuts off the changer. Any ideas?
The rest of the story:
My old 1959 VM Console's record changer recently began playing very slowly, etc. So I undertook the process of researching and repairing it. I took video of myself just in case, cleaned it all up, re-lubricated everything needed, reassembled, and I'm using a zip-tie to hold the motor up from sagging until the new mounts get here. Sounds good as new!
I've watched the video I took of my repairs and cannot find any re-assembly issues, but I must be missing something.
When I load a record and swing over and lower the overarm, then turn the switch all the way like normal, it drops the record, picks up the tonearm... and then just sets it back down and shuts off. HOWEVER, by happy accident, I discovered that if I hold the overarm up even 1/16" when the record drops... it works normally. The tonearm raises, backs up, then swings over and sets down perfectly and starts playing.
Aside from the overam now moving up and down much easier and smother than it did before since I cleaned everything up... I can't see where I made any changes... I was wondering if the information regarding how it will work one way but not the other might draw up some ideas?
Thank you for your time!
- John
TL;DR:
- John
