(...) Some time ago, I measured the T4P carts in my collection and found about 1mm in variation in length base-to-tip. (...)
(...) I also found about 1mm variation in tip height, which would make a difference as far as vertical tracking angle. (...)
Loaded or unloaded?
:scratch2:All the P-Mount cartridges must keep strictly some specifications.
One: The cartridge weight must be 6 gr.
Two: The VTF must be 1,5 gr.
Who knows more about?
Where can be found the "Official Specifications" of the P-Mount type cartridges?
Many earlier p-mount tables allowed for adjustment of VTF and antiskating (Technics SL-Q20 for example). Later models did not allow for antiskate adjustment, but you could adjust the VTF by turning a small screw at the rear of the arm that holds the counterweight in place...turn it L or R to increase/decrease VTF.
And also virtually no cartridge was designed for T4p from the ground up except for Technics. T4P was a good but in real world use, flawed system. Those who benefitted most from it, needed heavier tracking force options for records they took fair care of at best. Advanced audiophiles with better systems didn't need it on pivoted tonearms, and professional users didn't need it. It was an ease of use and convenience thing. Albeit a good one when done right for better records. There needed to be more T4P cartridges designed for T4p rather than existing cartridges adapted for it. I wish more conventional headshells for direct mounting of T4P cartridges had been made, I'd love one for the best T4p mount cartridges on conventional tonearms.
