RZ1
Member
About a week or so ago, I got myself a JVC AL-A158 P-Mount turntable with an Audio Technica 1001 cartridge. Specs wise, it was quite impressive (doubly so considering it is a cheap looking belt drive). 0.04% wow and flutter, 67db signal to noise ratio. When I tested it's speed, it was pretty much dead on perfect at both 33 1/3 and 45 rpm. It had a broken stylus though, so a new one was ordered soon after, and it arrived today (26 December). I was really exited to test it, and when it is working well it is great!
But then I found it had a glaring weakness- an arch nemesis: thin, light, mildly warped and somewhat bass heavy 1980s pressings. Amy Grant's "Unguarded" album was one such pressing, for example. When playing it, the tonearm would first skate across the first few beginning sections of the record and then eventually get stuck looping one part again and again, unable to get past it. No matter what I did (cleaning the record, reinserting the cartridge, changing the platter mat) it still skipped and looped. This frustrated me to no end. And this is on a new stylus! That said, other records, like the ones from Enoch Light's Command record label, played fine with no issues. Also, I don't think this is because of vibration. The speakers are on a mat, separate from the desk the turntable is on. Not to mention the skipping almost always happened on the same tracks in that LP, at almost the same parts.
My main turntable up to this point has been the Crosley C8, which I have moved to a different setup because I wanted to experiment with a P-Mount turntable in my main setup. It uses an Audio Technica AT3600L cartridge I set to track at 3 grams. This turntable breezed through that same Unguarded album like it did with any other record I played on it- no skips, no loops.
This got me thinking: Perhaps this is why no one makes P-Mount turntables anymore? I've heard that the T4P standard's mandated 1.25 grams of VTF and 6 gram cartridge often did poorly on warped records, but I thought it would at least do well on mildly warped records. I wasn't expecting it to perform that poorly. After all, aren't most old/vintage records at least somewhat warped to some degree? What are your thoughts?
P.S. Both cartridges (the 1001 and the AT3600L) are using a .6 mil conical stylus. I'm debating whether or not an elliptical would do better on a light VTF for the 1001. Also, I'm not using a record weight on either turntable- I don't have one.
