johnblue
Hello all, i have had this Packard bell DPA 30-1 for a while, i pulled it from a trashed console and all in all it was in working order. . i changed the coupling caps, and that's it... sounds pretty good, but a little "dirty". its time for an overhaul... i had another project that just got put on hold, so i might as well go balls out with this little guy. i've read its almost the same as the magnavox amps everyone loves, and i know that theres a few "famous" overhauls of this amp....
The DPA 30-1 is a little different from the more common DPA 30-3, in that it uses a PI filter with a choke... and the input jacks have coupling caps and a resistor, other than that its nearly identical to the DPA 30-3
its on the bench now and today i ordered some new rca and speaker jacks, some new filter caps.
There's something that i am going to do that most people advise against, and its disconnect everything from the 9 pin connector that powers the tuner/preamp.... so i am going to have to rework the power supply.
maybe you guys can help me with that... also there's a couple theoretical questions that i have regarding the topology as well.
i cant find a 250uf 25v cap for that area circled in the center that couples the two sides of the amplifier, im not exactly sure how that part works? is it a filter of some sort,? and can i up the capacitance a bit? can you guys explain how this area functions?
i put red x's where i took things out of the circuit, its not really running hot or anything, but im going to be removing the large can cap and using caps on a perfboard, so, im hoping to make some improvements, also, i have a few larger chokes im going to try.
