Hi all - I recently purchased a Packard Bell RPC-67 and am restoring the unit. I recently replaced all the electrolytics, but when powering the unit on, I get almost no low end out of the right channel. I took the power amp out and measured some voltages while powered, and noticed some channel mismatch at the output. When applying a 100Hz signal on the input, I get ~1V lower voltage on the right channel.
One mistake I made was wiring in the filter capacitors in reverse, and tripping the on-board circuit breaker, before realizing my mistake. Can this be what's causing the missing low end? No, right?
I am using the schematic found on this thread: https://audiokarma.org/forums/index.php?threads/packard-bell-dpa-150-console-amp-schematic.876884/
but it is blurry and I can't quite make out the expected voltages written there.
Does anyone have a tip for me or dealt with something similar before?
A clearer schematic would help as well, if anyone has access to Sam's Photofacts set 907 folder 7, and wouldn't mind sharing.
