Hi, I have a Panasonic RX-C39 portable stereo from 1984 or thereabouts. 10 or 15 years ago the cassette deck developed a problem in that it makes a grinding noise when you play a tape.
If you engage playback without a tape inserted, the deck acts fine. But when you play a tape, or when you play without a tape and manually stall the take-up spindle, it grinds.
I took apart the stereo, and it turns out the grinding is caused by a spring-loaded gear which, during playback, slightly retracts backwards, going out of mesh with and grinding against the gear it's supposed to be engaged with.
I made a YouTube video showing the behavior of the deck with and without a tape:
Fast forward, rewind, etc work fine. The two belts seem fine - the deck is able to engage into record mode, which I know needs pretty good belts to accomplish. With that said, I won't rule out less-than-stellar belts as the problem.
Any ideas? I've been told this is a common occurrence on this stereo. Thanks in advance!
