Panasonic RD-7703
It's BSR's entry level to decent. Not their best changer of the standard lineup, that has an adjustable counterweight, a 4 pole motor, anti-skating, a 1/2 mount cartridge slide mount, and a bit beefier motor than this one, but this one is a good one. The best of best BSR made would be the 610 and 810 family (BSR's attempt to compete with Dual and ELAC Miracord) or the Accutrac or Accuglide models.
I lowered the tracking weight on mine by tightening the spring, and while I was regreasing/relubricating the changer mechanism, added a ground wire/loop.
Reviving this thread rather than making a new one.
So, I'm looking to give this turntable to a buddy who wants one. I know it's not the greatest turntable, but it's in good shape and I got it for a song. Replaced the cart with a magnetic one I had on hand and shortened the spring to lower the weight of the tone arm. And it sounds way better with the magnetic cart, but.. the hum issue is pretty significant.
Looks like mine already has the ground loop installed. linking the two ground wires to the chassis, and that it might have been installed long ago, perhaps even in the factory. Hard to know. I'm still getting a significant hum. When you did yours, did it help at all? I'd be curious to see a photo of what you did if you're willing. Maybe I'm missing something here.I guess I could replace the original ceramic cart with another one, but that seems like a waste when I have a magnetic cart ready to go.
You'd want to use a Pickering V-15. These were designed for changers, as most used a 2-pole motor, which is the case for the BSR A46 changer in yours.
I eventually swapped the A46 for an A88, which has a 4-pole motor.
Thanks for the suggestion.
So I went down the rabbit hole a little on the Pickering carts and good gracious there's a lot to digest there. Pickering was gobbled up by Stanton and if I gather correctly, pretty much anyone who seriously uses them looks for used or NOS styluses as aftermarkets are hit or miss.
My problem is I don't know where to start. Obviously I would want a lighter tracking one, but I don'[t have the first clue of which one that would be. Obviously, I wouldn't want to pour a lot of money down the drain on an old bsr turntable, and I'd want the new owner to be able to find a stylus for it without having to search to the ends of the earth for one.
Gosh, being a newbie sucks sometimes. I'm a little overwhelmed with information and my lack of a background to fully understand all of it.
I recently scored an RD-7703 for $8 and was interested in more details on running a 3600, specifically how you do the ground. Oh and what spring was mentioned? How to you get to it to mod it. Thanks in advance if anyone responds to this attempt to revive an old thread.
I too just recently obtained an RD-7703 - mine does not look like the one in the video - mine is the BSR MA65, not the C141, had to clean it up some but works fine, don't know if I'm interested in putting a mag on it - like to keep it original
