Panlocs for C28, MA6100 etc
Martin Angus
Im building a custom cabinet for my gear and want to add panlocs for the subject models above. They typically come with L52 cabinet. I need to buy a pair off the bay but see that there are various versions and sizes. Can anyone help me identify the ones I need...dimensions etc?
Thanks in advance.
Larry, your compendium doesn’t mention the C28 or C26 preamps, or did I miss them somehow? I’ve gone over all 14 pages several times. Just can’t seem to find the C28 mentioned. The original poster (Martin) didn’t follow up on this thread.
I’d think that the brackets that fit the C24/27/29/etc. would also fit the C28.
But if my assumption is incorrect, can you tell me which brackets do fit the C28? Thanks.
Doug
Hi Doug, It is the 043-622/623 version. The most common, standard size. I fixed the PDF.
Thanks! Larry
Thanks so much, Larry. I’m going to make a repro L12 cabinet for my C28 out of solid walnut or cherry - haven’t decided which yet, but I have lots of rough cut lumber. I may not put a grill in the top since a preamp doesn’t get warm like an amp, but I do want to use Panlocs. Thanks again!
Doug
