So I just bought a pair of original Paradigm 5se's (not MKII or other versions) as the cabinets were in good condition, and the tweeters seemed to act fine. There are two specific problems with them that need attention.
1. Dust caps need to be replaced/reglued.
One of the dust caps was gone, the other was only half glued (the glue seemed to have just dried up).
I pulled the second dust cap because it was audibly buzzing against the driver and the glue had obviously dried out. It peeled right off.
How quickly do these dust caps need to be replaced and where can I get replacements? Parts Express? Paradigm 'doesn't sell or ship dust caps' according to customer service there.
2. Buzzing in one woofer at specific frequency
The first speaker stopped any audible buzzing when I peeled off the dust cap. I saved it if a reapplication is in order.
The second speaker is where I need some AK advice! It's the one that came without the dustcap if you're still reading this.
This speaker's driver has an audible buzz only at certain frequencies in lower octaves. Imagine listening to some rock music only to have certain bass guitar notes cause the audible buzzing.
I can't really 'see' any delam going on between the rubber surround and the driver itself, but as I started lightly touching the joint between the rubber surround and the driver, I found a spot where if I touch it very lightly while the speaker is playing music, I can completely eliminate the buzz.
I have no idea if I'm even supposed to touch a speaker while its playing, let alone if the speaker can be fixed with some refoam glue (I already have some from a JBL refoam project) but is that a good place to start?
I emailed Paradigm and they want $60/speaker to refoam and repair dust caps, etc. $120 to repair these is too rich for my blood. Doesn't seem like they'd be 'worth it'.
Any help would be most appreciated. Where do I start? Try and reglue the foam without removing it? Replacement foam surrounds from that auction site? Replacement drivers from PE that make them 'good enough'?
thanks in advance, I'm really hoping its something easy!
take care and stay cool
peter
peter
