Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
I was wondering if mid / bass speaker could be fixed an how to go about it. Whats going on is speaker doesnt work unless I touch the cone on one side or the other. When I hold hand on cone it works fine
You may have a damaged voice coil. Try rotating the position of the woofer 180 degrees and see if that helps. If not, you will probably have to replace the woofer.
